I put in my factory stage 1 jet kit. I have everything in and now i'm to the float height part of the install. I have the floats sitting on the float valve which is closed, but the float valve spring is not compressed just like the instructions, and I know i measure from the bottom of the carb body to the float to get the correct height. Here's what I don't understand. I measured the height(stock) and It reads roughly 5-5.5 mm's. The kit says to measure it out to 9.5mm. When the floats are sitting on the way they are supposed to on the float valve, but not compressing it, Where on the float do i measure to? When the floats are sitting like this, the skinny end of the floats are further back in the carb body than the larger ends where it connects. Do I just measure to the bigger corner in the back, and will i really need to adjust it almost 4mm bigger than what it is right now? or am i just measuring wrong. By the way, this is for an 01. If you guys could just let me know how to measure and where to measure it from that would be great. I can email pictures if it would help anyone to understand what i'm talking about. Also, if you have any pictures that you could draw a couple arrows on to show me where to measure, you could email them to me. Thanks
Life is short, but sweet for certain...
