Cleaning up a complete and stock 10 year barn find..
I've just disassembled and cleaned the 4 kei-hin carbs on a customers 1998 ZX600E and although the bike starts and runs fine through the entire throttle range from a gravity feed fuel bottle, when I connect the fuel pump and new filter it floods within 20 seconds at idle or even off idle. The revs slow down, sputters, and falls on its face. Plugs wet. Cleaned plugs, go back to bottle fed and it runs fine with no flooding.
Instinct tells me to check the psi from the pump, but I'm not sure I have a gasoline compatible pressure guage. Is the pump overwhelming the float valves in the carb bowls? Is the pump supposed to shut off when it senses back pressure?
An old thread on a different forum suggested the CDI/ecu might be holding old info from clogged fuel filter and calling the pump to put out a hight pressure than necessary - remedied by disconnecting battery for a while to clear "codes". But that didnt fix it and thatinfo might be very incorrect.
I really don't want to have to take these carbs off again.
Tia for any suggestions.
I didn't change or replace any interior carb components or readjust the float height on any of them. Again.. runs fine with gravity feed.
