ROFL... NOW THAT'S GOOD THINKING !!!Originally posted by Rob Lee
Many track riders reverse the pattern on their streetbike out of habit. The pattern also keeps others from borrowing your bike.
Huge Industries rear sets are available in reverse shift pattern.Originally posted by hotbag
Does anyone out there know how this can be done? I want to reverse the shift pattern on my 636.
"I'm from yeranus."
Im interested to!!Originally posted by alex2002zx6r
can this be done to a 2002? and if so, does the automatic neutral finder still work? i cant live without it.
All attached files are converted, resized and compressed to save space and to add the zx6r.com banner to those larger than 150x100. Avatars are only converted, if their diminsions are larger than 96x96. If not, they will stay ad .gifs. I'm looking at options to have a smilie manager for each member instead of using the attach feature.Originally posted by Strong Bad
They've been lifted from various forums and random late-night IMs while at the BIG MSU!!! Just kinda sucks how everything automatically gets converted to JPEG format, nothing is animated anymore!
But since there's the option to block the inserted files from coming up in the profile, is it possible we can at least use GIFs? (for all you mods)
Hey Canuck, can you post up a picture of what the pin looks like after you've reversed it. Did you have to offset the pin a little to get clearance on the sprocket cover? Doesn't seem like you can flush up the lever without hitting the cover.Originally posted by canuck51
I did it to my 6rr, all you have to do is rotate the clamp on the transmission pin around. The tricky part is that you have to remove the sprocket cover to be able to get the bolt in and tightened. Then once resecured, you just bolt the cover back on. If you need a picture of how it looks, let me know....
