Got the tank off and looking for spark plug location on 2000 ZX6R. HLEP! I can NOT find them!!!! are they under the air box? if so how do I take that off so that I can get to them?
Naz :cool:
the spark plugs are on top of the motor... if you have the tank off.. just simply take the airbox off and you will see the valve cover... there are four plastic plugs... disconnect them and pull them out.... the plug is in the hole..
2001 Yellow ZX-6R
K - I see that. Gettign them out of the hole now is my problem! No! I guess I need go get some deep throat sockets....or do they make a special socket you can take them out with? They are down there a long way.<img src=icon_smile_shock.gif border=0 align=middle>
Naz :cool:
I got'er done. Used a deep throat socket that will hold plugs with the rubber in the end, 2 different sized socket extensions, a little luck and a LOT of fanagling. I got em changed out though, but not put back together yet. That is coming tomorrow! I'll let ya'll know how it comes out.
Naz :cool:
