so i bought this bike not realizing all the things that were wrong with it, modified, reasons for talking down the price more, blah blah blah.
i found out the other day it was lowered in the rear with a generic looking dogbone. i went on a ride with a sport bike group a few weeks ago and had her leaned over far enough to get my chicken strips down to about 1cm and i was impressed with how it felt in the turns, but this is my first sport bike so i don't know how it is supposed to feel.
it has a 3 position adjustable dogbone on it and it is currently set on the middle hole.
i have a few questions...
1. how do you unload the swingarm so you can adjust move the bolt? i've heard everything from lifting the rear with ratchet straps from the ceiling in the garage to using a car jack under the oil pan. i've also been told you can bend your oil pan and make it leak if you jack it up there.
2. how likely am i to throw the rear out of wack by going back to stock height? i have no idea if they previous owner actually had it tuned at this height or if he just lowered it and ran with it like that.
3. i've heard there is a washer or shim that can be removed to lower the rear height. can anyone tell me where that washer is so i can check to see if it's still there while i have the swingarm unloaded?
4. is there anything else i should be looking at while i'm down there?
thanks a bunch!
jacob
thanks a bunch!
jacob
