Hi I have a 2005 zx6r bought it used so I was trying to make the kickstand feature were when its down the bike will not move the connecting under the gas tank is plugged in but its not working was trying to trace the wire in the harness but can't find it i wanted to no if It goes straight up to the cluster cause I don't have a cluster and I would like to get the feature working cause I seem to make this habit of moving with my stand down so I would like some help in finding which wire it is and if its possible to work with out the cluster thanks in advance
OK
First off I assume you have the side stand switch installed (fitted to the side stand) ?
If yes then is it plugged into the loom ?
Any pictures would be helpful (y)
OK
Hi I have the switch plug in and its on will post the pics now
