1 - 8 of 8 Posts
So after a LOOOONNNNNGGGG time finally put the bike back together. At first wouldn't start which we traced to a battery in need of a lonnnggg slooowww charge. Now she starts but the FI light is on. Rode her around the block and found out she wont rev past 5K. Motor doesn't scream or rev it's just like there is nothing past 5K and it's doing it in all the gears.
Any help would be greatly appreciated.
How do you pull the codes? I'm having the exact same issue.
What do you mean Frodo body?
Assumimg your saying throttle body what was wrong with your old one?
I'll pull up the manual tomorrow if not there is a couple right ups on here if u look in search and yes its throttle body. A small black sensor on mine is showing up bad didn't test it just swapped with another set and she's fine.
Discussion Starter #8
Now that she throws no codes find from about 10000 rpm to just before redline its like something its holding her back. No codes at all and pulls like a freight train once she clears out. Any suggestions
1 - 8 of 8 Posts
