1 - 2 of 2 Posts
i know this should be in the how to forum but theres nobody viewin there and theres 11 viewing here.....i bought a license plate bracket....i have a euro tail with flush mount blinkers.....i want to put the bracket on and attach the blinkers to it.....how do i take the undertail off......call me a newb i know.....but i need to get it inspected and where my plate was nobody would do it....right now i have the solo seat off and the rider seat off....
pretty simple,
there are a bunch of those black plastic push nuts all around the outside of the undertray, you take all those off, then you need to remove the plastic "trunk insert" (held in by a phillips Screw) then also remove the 2 Phillips screws on the top side of the tail section. Then you will need a 10mm socket to unscrew the metal "tie down" bracket and remove that... the undertray should be floating there now... you need to remove the upper part of the tail assy first it has 2 plastic mounting points near the drivers seat... you need to Gently pull one side at a time out of the rubber mount and up, you may feel like your going to break your tail but just be gentle and it will come over (poor design IMHO)
my notes dont cover absolutly everything but if you have some inginuity you should be able to fill in the gaps.
1 - 2 of 2 Posts
