Just check it, if it has too much play in it, it's time to adjust it. Generally, that means pushing it up/down about 1/2 way between thr front & rear sprokets. It should have soem play, but not too much. Sometimes you'll also know cause you'll hear it...meaning adjustment was likely way overdue. Check the manual for the exact rage of safe play.
