had my bike sitting in the garage for a couple of weeks and now it seems to have a hesitation when giving it full throttle. hesitation is momentarily and then it takes off again. anyone else had this problem or something similar after the bike had been sitting? help is appreciated. thanks :D
Are you still on the same tank of gas? If so, give it another tank or two and chances are it'll work itself out.
i had the same problem, i just bought my bike used and the guy said it sat for six months i believe. I put some fuel cleaner in went throug that tank and then threw in some 104 octane mixed in w/ 93 and it runs alot better, doesn't hesitate so much any more. Once and awhile it does. I was thinking the carbs needed synced.
i put some sea foam in and ran part of the tank before it sat. ill try to run as much as i can and see if it goes away. i still havent put it away for winter yet. im in central illinois.
