Man, I just installed some HID lights on my brand new ZX10 and wow! Unbelievable! They are so nice but I'm having a problem. Before I installed the HID kit I could toggle between Hi and Low beam. Now with the new kit It constantly stays on Hi and Low beams and I cannot toggle turn off the Hi beam. The HID bulbs are the same as the Stock headlights. H9 and H11. Any suggestions?
If They Are True Hid Kits, You'll Need To Hook Up External Relays Accordingly. I Had The Same Problem With My 06 And That Solved The Problem. You Might As Well Diode Isolate The Wire That "triggers" The Relays So There Is No Feed Back Into The System. Good Luck.
