Weezy,
I've seen some pretty unusual things at the heart of this sort of problem, and your specific situation may very well be among the list, but I would focus on the all the classic causes first. Tire and tire/wheel balance must always be considered, even when the tires look good and you 'think' they've been properly balanced. They are indeed the number one culprit. Most dealers and shops unfortunately don't actually balance the wheels correctly. The accepted (and quite improper) technique is to mount the tires with the yellow dot (light spot) adjacent to the tire valve (assumed heavy spot) on the wheel. You can take a look and see if this is the case on your bike. I questioned this many years ago and have routinely checked to see where the 'actual' heavy spot is on any wheel and the fact is, the tire valve has absolutely no bearing on the matter and is just as likely to be the lightest spot on the wheel. I know this is a little complicated, but the results can be significant. If the tire's and wheel's heavy spot wind up coinciding, the result will be too many wheel weights, but when they wind up being 90 degrees, or so, apart you'll wind up with some pretty serious dynamic balance problems. The reason so many folks continue to do this incorrectly is that most service manuals specify this. It is a hold-over from the good old spoke and steel wheel days, when the tire valve's weight was actually the deciding factor. I have corrected many wobble demons in just this way. It does mean re-mounting the tires so you may want to hold off until the next set. You may also have to explain the facts of life to the service department because they probably won't have any idea what in the heck you're talking about.
Have you checked the steering head play? The problem here, even with a new machine or perhaps especially with a new machine, is that clearances can become excessive quickly as the grease gets worked in.
You mentioned that the wheel alignment was OK, buy exactly how was this checked?
So many times the problem winds up being one of those things that the owner looked at and has assured me that it was OK.
