Alright, this is not for my ZX6R, it's for my EX500. I changed the oil today and overtightened the drain plug a little too much and it came loose. I pulled out the drain plug and there was metal carved right in between the threads so I damaged the thread in the oil pan. I tried using teflon tape but it is still dripping oil very very slowly. So, for now, I wrapped up the entire bolt and washer with teflon tape to stop the oil from leaking. Any advice?
You have to drain all the oil, then drill and tap the hole with new threads. You will have to use a larger thread size and larger bolt. Figure out what size the original is and then buy a tap the next size up. The tap will tell you what size drill bit to use. The hard part is going to be getting everything in a position to drill. You have to be pretty straight.
How the hell did you over tighten it? with an extension bar or something?
Buy yourself a torque wrench, it will pay for itself before you know it.
Nope, I didn't tighten it with an extension bar, just with a socket wrench. I'm pretty strong dude! Anyway, I guess I'll do the whole drill thing with going up one size bigger. I bought a torque wrench immediately after, and while I was at it I adjusted my chain since I knew what I had to torque the rear axle nut to. Peace!
