1 - 13 of 13 Posts
im gonna be getting my exhaust and power commander soon but i don't want to pay a shop $182932430483 for installation and whatnot. how hard would it be to do myself? also what kind of tools would i need?
thanks
Power commander is easy...just follow instructions...the exhaust...if it's just a slip on, that's easy, too...if it's a full system, a little bit harder...
not hard at all man. to do a slip-on and the pcIII at the very least you would need the hex bolt keys from the tool kit to take the fairings off, and needle nose pliers to get the clips off the injection wires. its gonna take a couple of hours cause you want to take you time and be careful with all your pieces and make sure you do it right the first time.
You should have no worries on the install of the pipe and PCIII
hardest part is getting the wire connectors apart, otherwise all straight forward and nothing to tricky..
if you need a map PM me your email i will send one over to you
Discussion Starter #6
thanks. the local shop quoted me $2200 for an arata full pipe, pc and dyno tuning... im thinking i could probably save a lot of money doing it myself.
Discussion Starter #7
alright so im trying to think about all the things i'd have to do when it's time to install and this is what i've got:
new header gasket (11060-1203), also a new air filter?
anything else i'd have to do? your help is greatly appreciated!
Don't forget the condoms, and be gentle, she's a virgin.
I did mine myself and found it to be very simple as long as you take your time, and concentrate.
Took me about 3 hours. I did have to lift the gas tank to install the pcIII. I got a DynoJet and a Micron exhaust.
Have fun...
---Anthony
fap-o-caster
Hardest thing for me was to take the gas tank off for the pciii install. I'm a wrench noob and I did it with little difficulty. I did my slip on first then a week or so later, the pciii.
strat
Sportbike Scum; Ex-Mod.
It all depends on how mechanically capable you are... some people can do this in their sleep after drinking a keg of beer. Others should never pick up a pair of pliers. EVER. Most fall in between those two extremes.
The pipe & PC are not really that difficult, given a little bit of savvy & the right tools. Take your time, double check everything, and do it right. Be sure you torque everything to specs... not too much or too little.
Good luck & have fun. Not much feels better than the satisfaction of doing something like that yourself & enjoying the results.
Neutered
2006 MV Agusta F4 1000S
I agree with everyone saying it's easy. The exhaust goes on the way the old exhaust comes off, and it's all just unbolting it and pulling it off. It should be very straight forward. With the PC3, the instructions are almost TOO easy. Mine came with a little installation booklet with pictures of all of the relevant connectors, and where they're located. Once I got all the panels and the tank and airbox off to get access to everything, the actual install only took like 10 minutes.
1 - 13 of 13 Posts
