Your 911 is high performance relative to automobiles, and bikes are all high performance considering the HP/liter. Consider the 650, say 70hp from .65 liters, that would be equivalent to a 3.0 liter engine putting out 315hp, without a turbo. That's not shabby by any stretch. Now compare a 1.0 liter bike stomping out 180hp...
Exhaust gas temps get screaming hot (turbo cars can exceed 1600°F easily), but by the time they exit the canister they're cooled quite a bit.
Motorcycles may have small engines relative to cars, but they can produce just as much heat!
I did some googling and found that motorcycle exhaust gas temps (at the engine) can float around 600-800°F at idle and exceed 1200°F at WOT.
The pipes will always be much cooler than this, but this is why ceramic coatings and header wraps are designed to withstand 2000°F... The muffler will be much cooler considering it has insulation and often times a heat shield. I wouldn't expect it to exceed 600°F though, so the 1200°F paint you used should work great. I'd still make sure the surface is prepped properly to ensure the paint sticks.
