1 - 20 of 44 Posts
$12 plus shipping, I bought the parts from www.svc.com, search for 80mm CCFL.
Link to Search:
http://search.store.yahoo.net/cgi-bin/nsearch?unique=32e6a&catalog=svcompucycle
All I used were the 2 fans, with the CCFL tubes. There was heat shrink, from my place that I also used. But basically, there were no additional parts.
I wired the front light to the halos, cause I got a fix it ticket for the green front light, and the switch kills all the lights. I'm sure you could make your own wiring system, but this one works for me.
CCFL Fan
CCFL Fan and tools
Opened fan
Close up fan
Removed Light
Cutting zip tie
Separated
Wires
Toggle switch
Removed Toggle
Computer wires
Removing needed wires
Removed Wires
Clipping power wire
Wiring harness
2 CCFL tubes
Plastic off CCFL tubes. Note: I left the plastic on, when I installed it on the lights, it was a tight fit, almost like it was made to be put on like that.
Inverter, you need this, I believe it inverts the the power from D/C to A/C or something like that.
All connected together
Continued in next post.
Discussion Starter · #2 · (Edited)
CCFL light test
Front fairing off
Front fairing
Taking off headlight
Headlight assembly
Where I attached the inverter. The fans come with Velcro.
Bike with no headlights
Prying apart headlights
Heatgunning the headlight to rip it in pieces.
Pulling apart headlight. Note: I heard you can bake the headlights, but this way worked for me, you can bake em, or whatever you want to do, to get them apart.
Front headlight
Front headlight assembly
Attaching CCFL tubes
Headlight boobs
Clear silicone sealant. Note: This stuff dries on clear, and reacts well to heat, so they won't move, or pop out with vibration, I highly suggest using some type of sealant, as the CCFL tubes could potentially move
Wiring it out
Number 2 headlight
Sealing number 2
Close up of sealant
Continued on next post.
Discussion Starter · #3 · (Edited)
Wiring both through
Testing
1 eyed headlight
Wiring picture
Put back on rubber seal
Reattaching headlight
Reattaching front fairing
Wiring
Inverter wired up
Attaching underside panel, with attached inverter
Switch. Note: I haven't attached the switch anywhere, it just hangs loose, I plan to get a marine grade switch that is water proof and attach it somewhere, but for now, it works as is.
Lights on, headlights off
Close up
Lights on, and headlights on
Lights off, and headlights on
How I wired everything up.
Thoughts and notes:
I touched the bulb upon replacing it, so now you can see fingerprints on it, but you have to be looking for it.
I tried to angle the dark spot on the halos to the bottom, toward the center of the fairing, on both sides, but it turns out you can see them pretty clearly, and it would be better if they were angled towards the top center, or even top outwards.
This took a total of about 3 hours. I wired it all, not the to electrical harness because that part is expensive to replace, wire it to the headlight wiring harness, please.
Any questions?
Discussion Starter · #9 ·
If you like them, I think you should do it. It's definitly worth it. They're only a, what?, 450 dollar headlight assembly? ;-)
The part that made me most afraid was the baking, but since I didn't have to do that, it was cake.
Seriously, I had cake afterwards.
if you baked them it would have been a lot easier...
200 degrees for 10 minutes and it pulls apart... same thing when you put it back together...
hey could you please give a little more detail on the wiring part?
i didnt get how you use switch to control that. where did you put the switch?
Banned
I dont understand the baking part, what the hell is that. You put the headligt inside an oven and they come apart more easily or what...
Great write up!
I plan on doing this to my bike as well. Just one thing I feel I should mention...
To all the guys doing this mod, be careful where you mount the inverter. Put it someplace where it will stay cool and dry.
They tend to get kind of hot even on their own, and have been know to actually smolder and melt themselves sometimes. This is when used just in a computer case - mounting it too close to a header or hot engine would be a lot worst.
FYI, they take 12vDC and turn it into like 680volts AC, or something rediculously high. House mains are 110-120 in the USA. Even though it is comparatively low amps, that kind of voltage is still not something to take too lightly. I personally had one of them running dual 12" ccfls for 24/7 for almost a year without incident, but just throwing it out there that it is possible and I have seen pics of them basically melting themselves.
Discussion Starter · #14 ·
At the moment, my switch is just hanging there by the wires. As for wiring it in, look at the diagram, it's wired, so that it'll kill the center light, and both halos.
Discussion Starter · #16 ·
I took pictures before hand, because I thought I wouldn't need them. But upon putting them on, I decided to continue using the plastic, because the fit was so tight. You could, also assemble it without using the plastic.
In short:
I just wanted to show how they were assembled.
1 - 20 of 44 Posts
