In the article "Give It a Break-In" in their February 1991 issue, Motorcyclist asked four top engine builders—Jim Leonard and Al Ludington of Vance & Hines, Nigel Patrick of Patrick Racing, and Rob Muzzy of Muzzys—how to break-in a new engine for peak power output and optimum life. What follows is a summary of their break-in recommendations.
Initial start
(If the engine was run at the factory or properly set up by the dealer, skip this step)
Start the engine only to bring the oil and coolant up to temperature with little or no load. Stop the engine and check for oil and coolant leaks. Then allow the engine to cool to ambient temperature.
First ride
Ride for 10 to 15 minutes at 3,000 to 5,000 rpm. Vary the engine load and avoid top gear. Then allow the engine to cool to ambient temperature.
Second ride
Ride for 10 to 15 minutes at 5,000 to 7,000 rpm. Vary the engine load, use short bursts of acceleration, and avoid top gear. Then allow the engine to cool to ambient temperature.
Third ride
Ride for 10 to 15 minutes at a maximum of 8,000 to 9,000 rpm. Vary the engine load, use short bursts of acceleration, and avoid top gear. While the engine is warm, change the oil and filter—use high-quality low-viscosity conventional oil such as Valvoline SAE 30 motor oil. Do not use synthetic motor oil.
Subsequent rides
Ride for 15 to 20 minutes gradually increasing the engine load toward redline. Avoid lugging the engine but rev it freely, especially in the lower gears.
After 250 to 500 miles, check valve clearance. After 500 miles, check the steering. After 500 to 1,500 miles on conventional motor oil, change to synthetic motor oil.
Initial start
First ride
Second ride
Third ride
Subsequent rides
