1) Put you gear on. Helmet is a must. Safety first.
2) Lean over and engage the front brake lever and mount your motorbike from the left side and stand it up. Kick the kisk stand back. It is now safe to disengage the front brake.
3) Check your kill switch and fuel tap and make sure they are both in the "On" possition.
4) Insert key into the ignition and turn to the "Start" possition.
5) Engage the clutch with your left hand, make sure your bike in in neutral, then with you right thumb, press the start button untill your bike is running.
6) With you left foot, press jently on the gear lever untill your bike in in first gear.
Now your ready to ride.
7) Get familiar with the friction zone of your bike. Keep in mind that ALL bikes are different.
8) When the bike begins to urch forward DON'T PANIC, just give your bike some throttle untill you get to a comfortable roll. When up to speed it is now safe to let go of the clutch lever all the way. You did it!!! You are now riding a motorcycle.
Switching gears.
9) Disengage the cluth by simply pulling the clutch lever inward while simultaneously closing the throttle.
10) Place the toes of you left foot under the gear lever and just flip the lever up once all the way. Then engage the clutch and give it some gas.
Just give this some practice and you are bound to get used to it.
Switching gears.
