hey guys i just installed my hyper pro damper last night and when i move the steering wheel left to right it makes a squeaky noise like its rubbing against plastic. just wondering if this is a common problem or did i not adjust something right.
ok i looked at it closer, the reason its making squeaky noises is because the bracket on the bottom is moving....it has like a lil space between the bracket and the frame. when i move it left to right the gap moves up and down
help anyone is anyone eles having this problem. i figured out the problem about the squeaky noises, but is my the lower braket supposed to move?
mine did that too, removed the rubber piece that went between the frame and tank with the oem rubber stopper. it sets the tank lower so it's pinned against the frame instead of up in the air. worked for me. no more squeeks
