1 - 2 of 2 Posts
I made my own homemade fender kit today. it looks good, but i bought little lights at my local car shop for turn signals. built for a 12 volt system, and now all my signals blink real fast. doesanyone else have this problem.. and is there a remedy besids going back to stock. there's a nother fender kit i'm ordering in a little while anyway (botbodys.com) but it just annoying as hell.
When you change the wattage of the bulbs it will cause the turns signals to flash fast just like there was a bulb burned out. You can correct the problem by going to an aftermarket solid state flasher relay available at Auto Zone for about $10. It is not a direct replacement. You will either need to cut the terminal off the wiring harness or make an adapter.
1 - 2 of 2 Posts
