1 - 2 of 2 Posts
My idle adjuster cable came out and i dont know where it connects to if anyone knows or has had this problem please help me out. thanks.
Mine did this also,I can't remember exactly where but I think it goes on the end of the throttle bodies which is tight behind the frame rail.It was a real pig of a thing to get in,I did it from the underside by removing the side panel.I think you could get it from the topside if you raise the tank too.I'm pretty sure its almost directly above where the end of the adjuster clips to the side panel,the cable has quite a bend in it which makes it a pig to get the threads started.Good Luck
1 - 2 of 2 Posts
