1 - 8 of 8 Posts
ok i never really noticed my idle before, so i dont know what it used to idle at before i got my exhaust. i noticed now that it's idling at around 1500-1700rpm's is that normal?
after warm up my '06 idles at 1K. sometimes there is a slight flucuation and it bounces back and forth betwee 1K and one bar past. for me thats good enough
You can adjust the idle on the lower left side of the bike. its a little black knob by the left rearset that you turn left or right to adjust idling.
Adjusting the idle may be a quick fix, but you may run into problems later with the FI. If you put on a full system (and hopefully a PCIII), I would suggest getting the PC mapped. If you have a slip on, adjusting the idle would be just fine, but that is a huge jump from 1300 rpm.
1 - 8 of 8 Posts
