1 - 9 of 9 Posts
My bike alarm arrived in the mail today. The Scorpio SR-i500. Figured out on my own how to take the tail and seat off without managing to break anything :)
The alarm comes with an ignition/engine remote kill feature and I am trying to install that module but it requires cutting into the ignition/engine wire. The installation book that comes with it says that the wire is brown with a black stripe "on most Kawasakis". If anyone here knows of the exact wire color and location for the 03 6R would you please tell me. If you would be willing to take a picture that would be awesome too. I did find a brown wire with a black stripe but I'm not willing to cut into it (so far its the only part of the installation that requires cutting).
If u do a search on "Eruo lights" or "runnig lights" there is a pic of all the ignition wires in detailand descriptions of each wire
Hope it helps
Checked it out and it didn't seem to show anything about the ignition wire.
Cut the Green/Black wire it runs from the fuse box to the cdi/ignitor box.
If your trying to stop the bike from cranking cut the Red/Black wire going to the fuse box.
Perm12v is white
Ignition12v is brown
Earth/ground0v is Black/yellow
Indicators are Grey & Green (test as there are several)If you connect to the indicators you will need to diode the indicator realy
If your not sure how to do it leave it ALONE!!!!!
its the ignition wire i'm after.
The remote ignition kill module has two wires coming out of it. Im suppose to cut the ignition wire and attach both ends of the cut wire to the module. So basically the module acts like a "man-in-the-middle".
Discussion Starter · #7 ·
Thank you for your help, I will tell you how it goes tomorrow.
Can someone post up as many wire colors they now of? I tried to install a remote starter on my bike but I was unable to for a few reasons. I need a few more wires.
***I already know of the risks involved so I do not need a lecture on why I should not intall it***
1 - 9 of 9 Posts
