alright, so i have my triple tree unbolted and basically removed. however, I cant move it much because my ignition is still attached. I need to know a couple things, can i get to the wiring harness on the other end of the wiring to unplug it and be able to move my triple tree to my workbench, or do i have to separate the ignition from the tree first? Also, I know ppl have talked a little about this here already, but i need a lil more info on removing the ignition assembly...I know there are two security torx bolts holding it in place. I am wondering if i can just drill into the center and get the head off, if the assembly will then simply slide off, and then I use pliers to turn the ruined bolts out, and replace with new ones. I have read that some ppl have drilled the center out, then used a torx bit or security torx bit to remove the bolt. What i dont understand is if you drill the center out, how does that leave the proper hole for the torx bit? Please someone just explain the easiest way to get the lil bastards out. I know this post prolly sounds completely confusing, but im tired. lol.
THANKS for any help guys.
Kevin
Kevin
