Anyone know how to sync the carbs without any special tools? If you do need special tools what do I need? Also, Are you supposed to sync them after you adjust the idle?
Thanks
If it ain't broke don't fix it.......yeah right!!
You need a vacuum gauge to properly check the carb sync. Check the idle speed, check and adjust the sync, and then check the idle speed again.
The Carbtune II, my tool of choice, does not use mercury. It shows the intake vacuum using floating columns of stainless steel.
You can get mercury vacuum gauges from Motion Pro.
