21 - 22 of 22 Posts
hey bro did you get it fixed? i had same bogg problem till today. i changed my carb floats from 15mm back to 19mm. much much better. fixed everything with that. i had originally run the 162 mains and just stepped down to 158. don't like it. pulled much better with bigg jets.
Also i noticed the needle will float between the vaccum diaphram base and the spring mount on top of it if you don't have 2 washers at least top or bottom or combo of both. this could have had huge ramifications as i had reduced mine to 1 washer allowing the needles to float up and down randomly. gey.
good luck
Bet some of you wish youd left them alone? I've done this on 3 bikes and each time I resorted baton stock. Jet kits are a bloody pain
21 - 22 of 22 Posts
