Have an 05 636. I recently installed an Arrow Ti slip on, Fenderkit.com fender elim, CA rear taillight and front turn signals. Problem is, the bike's battery dies after sitting for anything more than a day. I always take the key out/ignition off. The FI light fix Arrow supplies sucks and doesn't work, could that be the problem? or something else? Any suggestions would be helpful, thanks.
Yes, your problem showed up after you did some electrical work. Go back and look at the work you did and see if you shorted out a wire, etc. Cause the chances are that when things are fine, you do electrical work, and there are problems, the work has something to do with it.
Got any pics of what it looks like after all that? Bet she looks really nice. How does the Arrow sound? I want the full system.
Well a blown fuse or open circuit wont draw any more current.. It may be shorted but still have enough resistance to limit the drain to a few amps instead of just starting a fire (if the circuit hasnt been fused)..
