I recently installed my Acumen DG8 plug and play model on my '06 ZX-6R (636). It was a piece of cake to install and program (I followed the instructions exactly on Programming). However, I was curious if it's normal for the Display to cycle through (no numbers appear, it just spins in a circle) when you are at a stop light in 1st gear.
Anybody with a Acumen DG8 please post up and let me know if this is normal. Also, sometimes when you downshift from let's say 4th gear, during the lag that occurs when shifting (and thus slowing down) the display sometimes will revert for a split second back to some other gear and then display the correct gear. Anyway, I'm assuming this is all normal because the display requires speed to send the impulses/ratios to the Acumen in order for it to calculate the correct gear. Just curious...
