007- That should be about it. You might want to loosen all of the bolts a little bit before actually removing them so that one bolt doesn't become over torqued and be a pain to get it off. Not sure how tight the bolts are on your pan. You have a new gasket with the pan? Other than that, sounds like you have it covered!
