Hi! I wonder what can be wrong when it says "click" in the steering when I break? Can it be a loose nut or a bad ballbearing?
Can I fix it my self, or should I go to a mechanic-workshop?[:0]
(pardon my bad english...)
my bike did the same thing, sounds like it's your steering stem....
to verify this you will have to lift the front end off the ground and suspend it so there is no weight on the forks, then gran the forks down by the wheel and try and move it back and forth, if it moves then your steering stem needs tightened or your bearings are bad...
let me know if you have any other questions...
