What is it from a stage III kit you figure you want / need ?
The stage III kits are generally made (at least in the DynoJet family) for older less efficient engines. All you need to do is scroll down the list of available kits where they indicate stage III is available and you'll see that they are generally older engines / bikes. The amount of adjustment required to optimize carbs for most modern day carb'ed bikes is provided by the stage I kits.
Check out www.dynojet.com, www.factorypro.com, or www.ivansperformanceproducts.com for more info...
