All factors remaining the same: no. However if, upon completing the circuit, you decide to check it out once, twice, or more specifically MANY TIMES, then obviously your fuel economy is going to suffer since its benefits are seen in peak horsepower and WOT at 13000+ rpms isn't the best way to be efficient. :)
im sure it does if you keep it up above 12K all the time. seeing dynos of the jumper mod, it only helps after 12 K or so...so normal riding you wont see a difference. i wouldnt worry about it.
