Hello I have a issue with my Kawasaki Versys 650 2015 fuel pump.
when I disconnect it from the hose or basically when I take the tank out of the bike, drops of gasoline comes out from the tube hole. I all ready change the O Rings inside but the problem persists. Is that normal or some suggestions for this issue. Thank you
Pursebully
If it only happens when you remove the tank, I wouldn't worry too much about it unless you remove the tank frequently. I would expect some drops to come out anytime the hose is removed. What happens when the fuel level is low?
I haven’t try with low fuel. Actually the problem is about when I accelerate the bike after 6000 r/min it turns off. I all really clean the injectors. So the mechanic suggested me that it can be the liking gasoline pump
