1 - 2 of 2 Posts
Hello everyone
I hope anyone help me with my problem with my ZZR 600 D.
My ZZR bogging around 7.000 rpm when I accelerate but I squeeze the clutch the bike go to the full throttle
When I put 1ST gear and drive off the bike go to the full rpm but i put the 2nd gear the bike bogging at 7.000rpm . Sometimes at low speed I squeeze the throttle at full the bike the engines goes shutdown
I checked:
-Spark plugs
-Other cdi
-Rectifier
-New fuel tap
-Air filter
- Carb had cleaned recently
Any ideas I´m desesperate with the problem?
Could still be a carburetor issue. I had the same problem working on an 03' ZZR 600 my buddy had. Is your bike fitted with an aftermarket intake or exhaust? if not you can make sure your jetting is factory and that your float height is within spec. Ultrasonic carb cleaning is also a viable option, try finding someone local who offers the service.Then you'll definitely want to do a carb balancing. If you're confident that the carbs are clean and balanced wouldn't hurt to check compression to see if you're chasing a problem that can't be fixed.
1 - 2 of 2 Posts
