Don't hold your breath.pm sent
I am getting the cables from a guy I know he is actually the one doing the deal I am just doing it on the forums for him I have a kit ecu myself and the first one will be here today I want to make sure they work on my bike then if it does then I will have him get more he says he can get as many as we need I will keep you posted $ 150.00 is far better than 500 .Are these the factory kit cables? If i's true, That is a good deal. I got a Kit ECU and a great Akra/ BMC Programmed Map.
My guy went on a drunken spree so he hasnt finished my cable yet I am not happy about it but what can you do I am going to try to push him to get them finished Its not going to be a factory cable but will work the same The kit ecu will change the fuel and the timing you can tie in your quick shifter to it you can raise the rpm limiter 300rpm and you dont need the powercommander all that does is fuelI'm pretty sure he means the racing kit ECU which is suppose to add like 12-15HP. Let me know what the deal is please. Also, what is the situation with the kit ECU and a powercommander III?
