1 - 18 of 18 Posts
Hi everyone, I have been looking around for a forum on Kawasaki's KLX450R and couldn't find one so i thought i would start one right now..
Please feel free to talk about this great bike. Discuss what you like and what you don't and if you have any mods or problems you would like to dtalk about, feel free to do so.
your bike is getting hot? from what I have heard the klx450 is very similar to the kx450f. My 450 was getting really hot and boiling the coolant over, I bought a Boyeson super cooler water pump and started running maxima coolantol. Bike hasn't boiled over yet and I have riddin it in conditions that would have rendered the bike unrideable and nbo problems. I would say that would be your solution.
Buying a KLX 450 R
Hello, I'm thinking about buying a klx450r and want to find out if there is any problems with this bike. I'm about 240LBS hoping i'm not too heavy for it
Hey Guys ! , NEED some urgent help !!! i HAVE 08 , klx , AND THE BIKE IS AWESOME ,
CAME BACK FROM A GREAT RIDE AND WASHED AND PARKED THE TING FOR ABOUT 3 WEEKS !
CAME BACK AND NOW IT WONT STARTED , EVENTUALL BATT WENT FLAT , AND i KICKED FOR 1/2 HR , UNTIL IT STARTED , THEN IT RAN GREA NEXT DAY KICKED IT AGAIN FEW TIMES AND HAD AWESOME RIDE ! WHEN i GOT BACK HOME , SAME THING ,W ONT START ! I though tit was old fuel issue , but carb is clean , I evene removed it to check ! gave her new plug and checked the spark , it is there ! now just checked valves clearance and they are perfect !
I have to be missing something !
Please help me out , getting rather sad about this !
Thanks in advance for any info !
Wow, were you in my garage?
I just bought one, rode it once, the battery is dead and I can't even kick the bitch.
I'm taking it back first chance I get. I rode the other day, it was hot. The bike ran OK didn't want to idle so good. The battery died after 4 or 5 times and it was a bitch to start. I have to use the hot start and kick it over. found out it was easier to roll down a hill. not so happy in GA
I am not allowed to post a new topic and i don't know whero to ask my question. So sorry that i write in that topic.
I have kawasaki klx 250 1996 for 2 years, and i don't know how to turn off the headlight. Is there a way to turn it off when i start the bike (because i don't want to destroy the battery. Sorry for my english i hope you will understand me and know the answer.
up grades klx450r 2008
i want to make it a firmer ride more like a kx450 any help on this and can i put a 19 in rear rim on this thing for the ice????
pipe?
450R personal history & (many) mods...
FWIW... I am the most-published writer of Dirt Bike Adventure stories in America...
http://www.pencikowski.com/TravelsAroundPlayaVista.html
Here's a story I wrote on my 450R... Test: Warp-9 Racing 19" Front Wheel on 450R URL http://www.pencikowski.com/articles/Warp-9.pdf
With this set-up, 450R IMO "best desert bike on the planet" IF YOU CAN KEEP IT RUNNING :-(
Background: I bought one of the first 450R's available (mistake; bike not properly developed or de-bugged). Bike purchased in UT. "Baja kit" added to get street-legal & plated.
1) Elec system too weak to keep the battery charged (solution = disconnect headlight plug).
2) Any overheat issue solved via Red Line Water Wetter (and I ride in the Mojave)
3) Added full F/R RaceTech suspension $1600 Yes it works. No, not worth the $/effort
4) Re-jetted etc
5) Added Steering damper
The bike NEVER idled properly (stock or jetted; neither did the dealers demo-450R's). Sudco told me the FCR-40 has a Kawa-unique idle circuit, much leaner than "over the counter FCR-40" with *press-fit* idle-circuit jets that cannot be replaced by me.
Bike can really haul-*ass but the lack-of-idle (or 3,000 rpm idle) kills it.
Serious issue (early bikes) is flywheel way-too-light.
I did use the bike in some major-league events...
Death Valley Rally bike test: KLX-450R and KDX-200 Note I used the KDX-200 as 450R "not consistent" in idle/starting. Bummer.
Team Red Line @ Bishop 3-day
Team Red Line @ Sierra Safari 2008
Sierra Safari 2007
Team Red Line on the Moab White Rim Trail
Ideally I'd like to use the bike on the upcoming LAB2V L.A.-Barstow-Vegas. Bike NOT running and won't start. Must be completely taken apart (fuel system & carb) and (whatever it takes) o-hauled. Bummer.
If anybody wants to contact me directly I am Paul P. (age-64, retired) in the Mojave [email protected]
PS>> I have a KDX-200 with every upgrade possible on the bike. AWESOME and stone-reliable. But then again, it's (honest) a $7,000 bike.
So I'v had my bike when they first came out in 2007. Would like to address some of problems that have been mentioned. I love the bike and yes like alot of things there's room for improvement. Battery issues was a main problem i found. after only a few good cranks the battery would die out and you'd only flood the things then start it. One thing that i found out that helps good was buying a battery tender. As most people know a Bike regardless of size will not charge a battery but only maintain it, especially on the Klx. Get a battery tender and plug it in when ever your not riding. Will make things easier for you and cheaper on your wallet in the long run. When starting kick the bike over a couple times to prime it first then use the electric start to start the bike. This technique saves you energy and your battery life.
Idleing Issues havnt been much of a problem for me Either. The Bike does have a mind of it own at times but all in all is rather reliable. Most of the time i find the reason why most bikes wont idle is because the user messes around with the idle screw or air fuel mixture screws to much and end up making things worst then before. If the Bike isnt running properly there's a reson for it and usually it's from minor mistakes or the simplest things being missed. For instance I had a customer that had bought a 2011 Kx250FI.... ran great! got all sandy and muddy, and now dosnt run worth a crap, came in the dealer ship angry saying the bike was crap and not worth the money he spent. Turns out the bike was fine just all the electrical connections had water in them as he pressure washed everything. Now the Bike Runs like New again. Like I said there is a reason why something dosnt work.
On a different Note I'd Like to hear what upgrades and after market parts people have done with there Bikes and how they perform.
Cheers!
Just f'd up. My 08 klx450 was leaking oil out of the sump tightened the bolt and snapped it just under the nut. Wtf do I do now?
Sent from my iPhone using MO Free
spring help
hello all , i jst giot a 08 KLX 450 and the spring is adjusted all the way and its not enough. i weigh 260. any advice on a different spring? thanks?
08 KLX 450r Colorado
Cheers!
I have had my KLX 450 for several years, I am the second owner. I primarily ride double and single track anywhere from 6k-13K above sea level. I have not had any ( significant ) problems with it at all (starter fuse went once). I keep the valves in spec, change the oil and run 91oct gas. am having some starter issues now, but will mess with that once the season is over ( either starter or relay ). She runs like a champ!
I have installed RT gold valves, Forks and Shock, with custom valving and springs to suit my weight and riding style. OMG ! FMF PB header and power core w/ quiet insert, de smogged ( no real noticeable difference I could discern other than some weight lose ( the bike is heavy to begin with )). Ballistic battery, Ricochet skid plate, Moose rad protecto units, EE handguards.
I have gotten the thing hot, but use the HSB and she fires up!
My FREE advise for everyone is get the factory shop manual and find a good shop to have your work done, nothing worse that being stuck out in the woods without a clue.
you would be able to maybe tell me what’s going on with my bike just got it out of the shop with overheating issues and it just refs out in every gear ONCE it is warm for the first 15-20 it runs like it should but after that it starts to act up I have been running around and can’t figure it out.
1 - 18 of 18 Posts
