A friend at work has a 1978 KZ400B1. A little about the bike; I have checked the compression and the cylinders are 6psi apart from each other on a dry test well within spec of the Clymer service manual. It has a bright orange spark with a hint of blue to both spark plugs. It's a single coil same firing so swapping plug wires makes no difference.
The Problem: starting the bike when it's cold is like every other bike, it starts and runs fine. The bike works great until it is good and hot and then it's like someone flicked a switch. It bogs out like it's flooded with any throttle opening except idle. It will idle all day at this temp but if you try and use any throttle it dies. But it will fire up instantly right away. If you don't let it cool down, it will only start to run on the left cylinder, the right one stays dead.
One other note, the right turn, low beam and some other light I can't think of doesn't work. This I'm sure is a ground problem behind the headlight.
This bike does have the emission control diaphrams on both carburators. Anyone have some ideas?
LGN
LGN
