Sorry if this question has been asked before!!! But does anybody know of a replacement bulb or mod to make the front turn signals on a 08 650R L.E.D????
I installed these on my '10 650R. I imagine the 08 would take the same bulbs. Very bright!
If you are gonna install LED turn signals on front and back, I recommend this flasher unit. LED Flasher Unit LF1-S-FLAT Specifications
Otherwise your turnsignals with flash like a strobe light.
I'm planning to use these, they will always run White, but when the blinker is activated, they flash Amber, however, you would have to modify the wiring so that you can use your blinkers as DRL's and blinkers at the same time.
Thanks guys! I ended up ordering 1156 L.E.D.'s from superbrightleds.com. Didn't get a flasher unit, my tailight flashes really fast cause I never added resistors, so at least now the fronts will kind of match. I bought the cheap ones, $5. Thanks for the replies!!
