Ok, the d and d slip on on my 95' ninja leaks exhaust around where there are maybe 8 little bolts, the bolts are coming off but look like they cant be srewed in because it is a circle hole. This leads to a really ugly sound as I let off the gas, the whole pipe shakes like hell and it sounds terrible, my question is is there anyway to buy new bolts or fix that? thanks!
1995 red and purple ninja zx6r
1997 camaro v6 3.8
1987 honda nq50! oh ya!
Matt, most likely the rivets are coming out of the can...Very common in some of D&D's older products. Have it re-riveted and you should be fine, otherwise,get a new slip on for the bike, and save a little money..
Rubber side down!!!
Help! haha I took it outside ( about 20 something degrees) and it is bellowing exhaust from where the pipe meets the can. When i accelerate it sounds nice but when I let off it rattles like none other[V]
thanks for the help!
1997 camaro v6 3.8
There is a copper crush gasket that goes between the header pipe and the muffler. They cost about $10 from the dealer and should be replaced each time the muffler is removed. Usually they don't get replaced and leak. A leak there will also cause popping and backfiring on decelleration.
