cut through the plastic, and pull the wire that releases that latch???
That would be an extreme though. I don't know if you want to cut through that plastic unless you don't mind losing your little "trunk" ...
same problem. push down on the seat and turn the key and pull out seat while still having the key turned. some of the cables from the lock got snagged in the hole the seat slides in to, or the hole has something in it.
12 gage to the lock,that should do it,sorry dude i couldnt rezist. i dont know how a 03 works but on my 98 i could peal the side panel away from the fender and use some long needle noise plyers and try the grab the cable
