1 - 10 of 10 Posts
when i lowsided my bike, my spools ripped off the threaded part of the swingarm so now i cant add spools to my bike to get it off the ground.
i will probably eventually replace the swingarm, but for the meantime will a long enough rod thru the rear axle work with bike stands?
i know the axle part where the rod would go thru is quite a bit higher than where the spools mount, so i wonder if ill even be able to get it high enough? or what?
what do you guys think??
It can be done!
A friend of mine has a home made one that works with a rear axle rod!
I'll try to post up a picture of it!
I thought about that a few months ago. I just need someone who knows how to weld, so I can make a custom stand.
here's a pic of my powers spools, Haven't mounted them yet but I think I'll just bend the cotter pin out of the way
Looks slick, I may have to fab something up like that...but if my tabs get ripped off, I'll just weld them back on...lol
GunRunner
The rear chain adjuster lifts are made by Gilles, they use a adapter on the stand that has a spool and it lift the Gilles piece and pulls the bike up.
you can use a rod thru the rear axle, but how are you going to remove the rear wheel if you do it this way?
The better answer would be to find a machins shop and ahve them reweld a new bung on the swing arm. Had a buddy here do the exact same thing and that is what we did and now he can use spool lifts again.
I'll try fabbing a set out of billet 6063...just thread them onto a piece of threaded rod...then if you have to remove the rear wheel, just unscrew them and remove it...
GunRunner
i had to do this once to adjust my chain & change my oil on a road trip to B.F.E. i ran a piece of wrought iron through the axle & while i lifted the back of the bike up, my friend slid jack stands under it,worked pretty good & it was really stable.
1 - 10 of 10 Posts
