Anyone know what would cause low compression other than worn piston rings?
I did a compression check and according to the service manual it should be between 139 - 215 PSI. I am getting 90 PSI on cylinders 1 and 2, 120 PSI on cylinder 3, and 180 PSI on cylinder 4.
I plan to pull the motor apart and change the ring since they are cheap, $40 a set, but I would like to know if any of the valve may contribute to this issue so that I can get it fixed while im in there.
Thanks
I did a wet-test afterwards by dumping just a little over 1 tablespoon of oil in cylinders 1 and 2. They both went up from 90 PSI to 140 PSI. From what I have read, this is most likly going to be worn piston ring.
Anyone have any thoughts?
Thanks,
That would indeed follow worn rings. While it would sound pretty likely that you are gonna open the motor up, I'd do a leak down test too.
My compression tester has a standard coupling on the hose to connect it to a gauge, or I can pull the gauge off and hook to an air supply. So while I can't do a true leak down percentage test, I can find the leak path.
Rings could be stuck or cracked too...either would surprise me. Head gasket, valves...all possibilities...but I must agree rings are most likely.
Hopefully the cylinders are ok.
Good luck, and let us know what you find.
While your in there might as well get a valve job, and put some fresh bearings on the rods and crank. Hell maybe even a new chain tensioner. When its all back together get the valves adjusted.
