1 - 8 of 8 Posts
my LP V flushmounts were working this morning. i check the connections, fuses, wiring, and i did a search to help answer my question. the damn bulbs came loose inside the turn signal. i was like WTF!
i never expected anything like that to ever happen, i was close to gutting my whole rear to trace any grounded wires. oh well, its fixed now, but i wonder how long they will last in place.
Discussion Starter · #2 ·
just came back from a short ride. one of them came loose again. i crimped them both the first time but one came loose again. i guess im going to need some new one then.
Glad you figured it out! When I got mine one of the bulbs was already loose in the housing, so I unscrewed them both and made sure the bulbs were secure before I put them in.
i disassembled the flushmount, squeezed the terminal to make it tighter, and slid the bulb back in. i have a 01 not a 03, so its diffrent from yours.
Damn that sux. Yesterday I was riding with a few buddies, and we stopped for gas and one of them was like, "Dude, one of your brake lights is out". Well, I pulled the bulb out to check it, and the filament wasn't broken, the damned glass part came apart from the copper and the wires inside pulled away! Luckily I was able to unscrew the copper part with a pair of pliers without breaking it. Must be all those wheelies shakin' things up;)
sorry, i should of clarified that question. How did you install the signals themselves to your bike?? I'm having trouble with mine. The hole should be the same....
take off the upper fairing. there's probaly a bracket holding on to the light on the inside.
1 - 8 of 8 Posts
