We like LSL frame sliders for their modular nature and simple installation. The recently redesigned crash pads do a better job of absorbing and dissipating crash energy than the previous model while giving it a look that separates them from other frame sliders on the market. The rounded edges of the plastic slider inserts reduce the chances of the slider hooking as it rolls over the ground, theoretically reducing the amount of damage your bike may experience. A light crash may only require the replacement of the plastic inserts. For more serious damage, crash pads are available separately from the mounting bases, negating the need to buy a completely new setup. The crash pads come in a myriad of colors, from solid black to chrome to carbon-look.
LSL’s frame slider kits are comprised of CNC-machined brackets and high-quality hardware. Simple to follow instructions are also included with every kit.
While the primary goal of these frame sliders is to prevent the frame itself from coming into contact with the ground, reducing the likelihood of a very expensive crash repair, they also reduce the amount of damage that would have otherwise occurred to bodywork and engine cases.
Available for the following Kawasaki models:
ER6f 09 and up
ER6n 05 and up
Versys 08 and up
ZZR600 05 and up (fairing modifications required on both sides)
Ninja 650 06-08 (fairing modifications required on both sides)
ZX6R 00-10 (fairing modifications required on both sides for 00-02 & 09-10 models)
Z750 04-09
ZX9R 00 and up (fairing modifications required for 00-01 models)
Z1000 03 and up
ZX10R all years (left side fairing modifications required for 04-05 & 08 and up models)
ZRX1100 all years
ZRX1200 all years
ZZR1200 02 and up
ZX14 all years
These are not yet on our website, call Mike at 866.931.6644 ext 804. If you have any questions about availability – send an email to FORUM at RIDERSDISCOUNT dot COM with the subject LSL and please include the year and model of the motorcycle you’re riding for accurate availability.
High-quality hardware is included in every package.
Crash pad with hard plastic insert and spacer removed.
The round metal portion of each crash pad is also CNC-machined.
These sliders are available in more than one color to match your style.
Blue sliders.
Red sliders.
Discussion Starter #2
We now have LSL frame sliders available for the Gen 4 2011 ZX10R.
The ones photographed below are the direct-mount style that require modification to the both sides of the OEM fairings.
The included instructions tell you exactly what the torque numbers are so you can be assured that your bike is assembled to proper specification.
All LSL frame slider kits come with top-quality hardware and clear installation instructions with exact torque specifications. After all, properly torquing these frame sliders into place is critical for maximum impact protection.
