I just purchased an '07 500R but it didn't come with a manual. How often should I grease the chain and change the oil? Thanks.
... just a thought... oil.. 3k... hows that sound... pretty standard... and for the chain... my tests prove... clean it with silicone spray, "turning the wheel with your hand" spray the chain and then wipe it down.. "turning the wheel with your hand"... then lube it with white lithium spray... and "turn the wheel with your hand" and wipe the excess grease off the chain... do all of this from the inside of the chain to the outside of the chain... you can get 10k miles from a gold 530 'O' ring if you do this ... keep an eye on it and when the chain looks dirty... it's time... see the gold..? trash the "sticky chain lube"...
