1 - 19 of 19 Posts
I picked up track fairings on my bike to use at the track that I plan on keeping on there for a while, but every now and then wanna ride with friends on Sunday mornings and what not. I can get the rear plate on there with ease with the bracket i still have as well as the rear turn signals. What should I do in regards to a brake light and headlights? Some guy I know if I remember correctly retrofitted a foglight that was insanely bright as his source of light up in the front and hooked up and LED brake light in the rear. Anyone ever done this or know how to go about doing it?
Well what bike do you have???? You can fit a fog light on the front ( thats what I did works great.) I used a tail light off a 07 zx6r for the tail. I have no turn signals I just use my hands.
Woops, don't know why I forgot to even include what bike I have lol. It's an 04 ZX6R. I figured fog light would be the best method, how do the connectors look like at the end of the fog light? I've never seen one up close in person, but I'm guessing it won't be plug and play to the oem connections right?
i did the same wit track fairing on my 636. i cut out the headlight and taillight shape and fitted them both pretty good.....
I run my racebike 05 zx6r on track and street.
-Headlight is a driving light. I mounted the bracket in the ram air hole and just remove the actual light from the mount and unplug it for the track. 2 bolts and 2 wires.
-For the tail piece I have the license plate hanger that bolts to my exhaust with 4 bolts. I fixed a brake light and turn signals on the piece so that the plate, turn signals and brake light all go on and off with 3 sets of wires and 4 bolts.
-I have no front mounted turn signals.
race faring on the street would look nice
I did it on my bike and love it... takes only a few minutes to go from street bike to track bike.
Don't use fog lights they suck for light I used driving lights pointing one up further than the other and get reasonable light out of them. I want to switch to a good set of real projector low/high beams like these but not right now.
http://www.rallylights.com/hella/50mm_modules.asp
Here's some old cellphone pics of mine when I first did it 3 years ago. I really should get some updated pics with a better look at how I did things
The front and rear signals - Standard flush mounts
Mirrors - stocks
License plate bracket - VFX kits ZX bracket with LED plate lights http://www.vfxkits.com
Taillight - Stock
Front Headlights - Projector driving lights and I cut a plate of plastic and then mounted the driving lights to the plate. Put 4 holes in the plate and then rubber dampers between the hole and the fairing bellow the lights to mount everything to the bike. Everything is made to slide out without removing the fairing.
Beauty covers - With head lights and signals it looks like a$$ in the fairing so molded some black plastic to create beauty covers I use when it's in street gear. They are held in place by the front flush mounts.
I'll get some updated pics
im doing a fairing swap on my zzr600 to a 06 zx6 sharkskinz kit. it looks so smooth and tough without any lights. i might run without any. and have the custom paint flow right up the front. without interuption. i might tape a flashlight to my helmet for night ridin
old bump... but any more ideas? i'm planning to switch to race fairings because my oem ones are completely messed up.
I am looking to pick up an 05 6r tomorrow with race fairings and would be doing the same thing converting them to street came on here for ideas... however I might switch to stock tail as I still want a passenger seat.
Here's my friend's street/track setup:
Track:
Street:
1 - 19 of 19 Posts
