Im just wondering what the maximum CC the 636 engine can be bored and stroked out to? A friend claims his 06 636 was kited to 755cc, I think he's confused or mis-informed and hes got 655cc's
If it were possible I am sure many of us on here would have already done it. So is 655 the max?
KWS shows a max of 2mm overbore = 674cc. Only runs you $4550 for the work [:M35]
Level 3 – 130 to 133hp prices starting at $4550: Drag racing, unlimited road
racing, top speed contests or hyper-street bikes. KWS offers over bore kits of + 2mm (674cc). These motors make 130hp+ and can be ridden daily on the street (+ Level, 1, 2)
JE custom pistons, block machined by Millennium Technologies, KWS pro Head work, Web Cams, Adjustable cam sprockets, Custom head gasket, base runs and final dyno tune, etc….
674 would be correct as i did this research about 6 months ago and decided i would just wait till i broke the motor and go from there.
When the time comes i will do this mod myself...being i know what i am doing...
Just need to see where they are sending the cylinders to be bored and replated..
Going to be cleaning up a head i have in preparation for this in the next year or so...
JD, I was actually just reading an article about the '05 zx6rr and how the head from the factory (this was from a bike straight off the show room floor) already had excellent porting and really didn't require any work. I wonder if this is the same case for the 636 head. Also noted were the cam sprockets already having holes for adjustablity. Besides the increased displacement, how much of a difference is there between the 600 engine and the 636?
well the heads are NOT interchangable..same with the pistons etc etc etc
This weekend i will take a good look at the cylinder head i have when i get the valves out of it.
I have seen the 6RR and it looks truly CNC'ed from the get go and top notch..The zx6R (636) i am not so sure about that..
Ok well Update i just dug it out...IT IS NOT LIKE THE ZX6RR
Right off the bat i can see the casting flash in the exhaust ports & around the spark plugs and the there are some hard edges around the valves...The inlet tracts look pretty good for a stocker, BUT there is a definete cast edges halfway down the inlet tract.the 6RR head i looked at was a very clean combction chamber,inlet & exhaust as well.
So i will update you guys on how it works out...Going to see about getting it flowed before and then an after
