I took a piece of sheet metal and cut it to the size of sticker and painted it black. Then I took the left reflector off the fork and left the stand-off portion on the fender. Found a screw that was the same as the threads on the reflector and screwed the plate(with decal attached) into the reflector standoff. This way, it isn't stuck to the bike and can easily be removed with one screw. It is exactly where the base reg call for it too, on the left fork. Oh, if you do it this way, make sure you use some loctite, or it will vibrate loose. I will get some pics later.
Keith
