these are the koso gauges. Dude was it easy to put them on? Do they work? I'm interested in buying them, but I can see that there are very small
I found it pretty easy though I'm an electronics tech by trade so no probs reading circuit diagrams etc. Hardest bit I found was finding a place to fasten the mounting bracket.
All the standard wiring is actually still in place so if needed it will be easy enough to change back to standard. For waterproofing it's covered with self sealing tape though.
Couldn't find anywhere that I could put the 2nd temp sensor (didn't look that hard) so it's just under the fairing taking air temp readings.
Guage itself is working great, even has the left/right indicator function etc. Haven't pushed the fuel gauge to see how accurate that is though. I've got it set to flash at 30% and that = about 13 liters into the tank.
Like any digital gauge there is a very slight delay in the responce from the tacho and speedo but it's so slight it's not worth worrying about.
One thing that I have found is that the speedo is reading low. When it's showing 90km/hr I've been told that I'm actually doing 98. Haven't had time to look to see if I can make it more accurate though.
Might try to make a better measure of the wheel circumferance to see if that effects it at all.
Unfortunatly didn't think to take pics of the install process but it did involve removing all the fairings (including upper ones around the headlight etc) so took a while. Was the 1st time that I'd had the fairings off the bike.
All it needs now is a bit of a cleen up around the hole left behind. Left it the way it is at the moment (as in no cutting of mounts etc) in case I find some way of mounting something onto them. It would look a little neater if I was to just them off though.
If I don't fill it in though it will make adjusting the headlight much easier.
Seriously, are you interested in selling the old gauges??
At the moment I'll be holding onto them CaliGirl. If I do decide that they are no longer needed I'll keep you in mind though..
