Okay, this is a continuance of some of the posts taht i have had on here. Basdically what happens is this. 1st gear, used to be able to only hit like 5 grand. Rode it for about 40 miles or so and will go to 9 now. Once it hits a certai point it starts to "jump" almost like you are going to fast in like first and let off the throttle how it jerks like that, but when it jerks forward it accellorates. 2nd I can hit like 6 grand and the rest is history. Still cuts off and 5. If it were some sort of fuel delivery issue, wouldn't all the gears be limited to that low of RPM's? I have exhausted EVERY idea I can think of. Did new plugs, oil change, coolant topped off, fuel filter on the way, new gas ran thru it etc. Still nothing is helping. I do NOT want to have to take it to a mechanic. The labor rates are horrible. Is it hard to clean the cabs if I wanted to try to do taht? That is the last thing that ran thru my mind, but wanted to know if it was too tough? I just need SOMEONES opinion to help me out here. Hopefully this sounds familiar or easy to someone. Thanks a ton.
Naz
Naz
